new to journaling
new to journaling
new to journaling
I am trying to write a journal where the user is prompted to select multiple faces of a block so that the journal can "Offset Face" a specified distance.
I have been able to put together a journal where a single face is selected and offset and I have example code for multi-selections. I just can't figure out how to combine the programs.
Any help would be greatly appreciated.
Kevin
RE: new to journaling
Here is what I have so far for a single selection, I realize there are issues if the user cancels out of the selection process but I think I can figure that out.
Also I would like to have the offset distance controlled by a user selected value from a dialog box, but first I need to figure out the multiple selections.
Thanks in advance,
Kevin
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module NXJournal
Sub Main()
Dim face1 As Face = SelectFace()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: Insert->Offset/Scale->Offset Face...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim nullFeatures_Feature As Features.Feature = Nothing
If Not workPart.Preferences.Modeling.GetHistoryMode Then
Throw(New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
Dim offsetFaceBuilder1 As Features.OffsetFaceBuilder
offsetFaceBuilder1 = workPart.Features.CreateOffsetFaceBuilder(nullFeatures_Feature)
theSession.SetUndoMarkName(markId1, "Offset Face Dialog")
Dim boundaryFaces1(-1) As Face
Dim faceTangentRule1 As FaceTangentRule
faceTangentRule1 = workPart.ScRuleFactory.CreateRuleFaceTangent(face1, boundaryFaces1)
Dim rules1(0) As SelectionIntentRule
rules1(0) = faceTangentRule1
offsetFaceBuilder1.FaceCollector.ReplaceRules(rules1, False)
offsetFaceBuilder1.Distance.RightHandSide = ".01"
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Offset Face")
Dim nXObject1 As NXObject
nXObject1 = offsetFaceBuilder1.Commit()
Dim expression1 As Expression = offsetFaceBuilder1.Distance
nXObject1.SetName("Grind Stock")
offsetFaceBuilder1.Destroy()
End Sub
' Selecting The Face
Public Function SelectFace() As Face
Dim ui As UI = ui.GetUI
Dim message As String = "Select Face"
Dim title As String = "Selection"
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim keepHighlighted As Boolean = False
Dim includeFeatures As Boolean = True
Dim selectionAction As Selection.SelectionAction = _
Selection.SelectionAction.ClearAndEnableSpecific
Dim selectionMask_array(1) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_face_type
.Subtype = 0
.SolidBodySubtype = 0
End With
Dim selectedObject As NXObject = Nothing
Dim cursor As Point3d
ui.SelectionManager.SelectObject(message, title, scope, _
selectionAction, includeFeatures, _
keepHighlighted, selectionMask_array, _
selectedObject, cursor)
Dim face As Face = CType(selectedObject, Face)
If face Is Nothing Then
Return Nothing
End If
Return face
End Function
End Module
This is the code I was attempting to use for selecting multiple faces:
' MultiSelection of Faces
Function SelectObjects(prompt As String, _
ByRef selObj as NXObject()) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim typeArray() As Selection.SelectionType = _
{Selection.SelectionType.Faces}
Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects( _
prompt, "Selection", _
Selection.SelectionScope.AnyInAssembly, _
False, typeArray, selobj)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Or _
resp = Selection.Response.OK Then
Return Selection.Response.Ok
Else
return Selection.Response.Cancel
End If
End Function
The current code uses a tangent face rule. When you switch to multiple face selections, do you want to use the tangent face rule or only offset the faces directly selected by the user?
Also, what version of NX are you using?
www.nxjournaling.com
Prefer to only offset the faces directly selected by the user. I assume I could replace "faceTangentRule1" with "faceDumbRule1"?
I am on NX7.5
Here is one solution:
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module Module4
    Sub Main()
        'Dim face1 As Face = SelectFace()
        Dim face1 As New List(Of Face)
        If SelectFaces("Select faces", face1) = Selection.Response.Cancel Then
            Exit Sub
        End If
            Throw (New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
        End If
        Dim faceDumbRule1 As FaceDumbRule
        faceDumbRule1 = workPart.ScRuleFactory.CreateRuleFaceDumb(face1.ToArray)
        rules1(0) = faceDumbRule1
    End Sub
    ' Selecting The Faces
    Function SelectFaces(ByVal prompt As String, _
    ByRef theFaces As List(Of Face)) As Selection.Response
        Dim selObj() As NXObject
        False, typeArray, selObj)
        resp = Selection.Response.Ok Then
            For Each tempFace As Face In selObj
                theFaces.Add(tempFace)
            Next
        Else
            Return Selection.Response.Cancel
        End If
    End Function
End Module
Cowski,
Thank you, that is very helpful!
Kevin
Cowski,
Is there any chance you could help me out again? I am trying to use AskFaceMinRadii with no luck.
I have added the below code after line 82 to the first code I posted in this thread.
FaceTag = face1.Tag
ufs.Modl.AskFaceMinRadii ( FaceTag, num_radii, radii, positions, params)
lw.Open
lw.WriteLine("Object Tag: " & FaceTag.ToString)
lw.WriteLine(radii.ToString)
I get an error that parameter radii has a null value, I can select the same face with "Analysis/MinimumRadius and it returns a radius value.
Any ideas???
Kevin
You must also declare the num_radii, radii, positions, and params variables.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theUfSession As UFSession = UFSession.GetUFSession()
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim theFace As Face
        If SelectFace("Select a face", theFace) = Selection.Response.Cancel Then
            Exit Sub
        End If
        'MsgBox(theFace.Tag.ToString)
        Dim numRadii As Integer
        Dim radii(1) As Double
        Dim positions(5) As Double
        Dim params(3) As Double
        theUfSession.Modl.AskFaceMinRadii(theFace.Tag, numRadii, radii, positions, params)
        lw.WriteLine("number of radii: " & numRadii.ToString)
        lw.WriteLine("radius 1: " & radii(0).ToString)
        lw.WriteLine("radius 2: " & radii(1).ToString)
        lw.Close()
    End Sub
    Function SelectFace(ByVal prompt As String, ByRef tempFace As Face) As Selection.Response
        Dim selObj As TaggedObject
        Dim title As String = "Select a face"
        Dim includeFeatures As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(0) As Selection.MaskTriple
            .Type = UFConstants.UF_solid_type
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            tempFace = selObj
        Else
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
        'Unloads the image explicitly, via an unload dialog
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    End Function
End Module
Thanks you!
I had them declared but not properly.
This is what I had:
Dim num_radii As Integer
Dim radii As Double()
Dim positions As Double()
Dim params As Double()
