ETABS 2013 - Display Mode Shape
Do anyone know how to display the mode shape after analysis in ETABS 2013..
I do not see the command which like ETABS previous version..
Thank you
RE: ETABS 2013 - Display Mode Shape
I had the same problem and contacted CSI after spending more time looking than I would like to admit. It is in the deflected shape dialog box. I am not at work, but if you click on the deflected shape icon, you should be see a check box or something for the mode shape.
