Double datum letters
The ASME standard certainly allows double letters to be used as datum feature identifiers, once the single-alpha identifiers have been exhausted (ref. para. 3.3.2). But here's an interesting question:
Since the single-letter designation doesn't have to follow alphabetical order, would you say that the double-letter designation also doesn't have to follow an order? The standard seems to imply that the double letters must, but that seems like a break in logic from the single letters.
In other words, if I have a huge drawing where I need 60 datum features (hey, it's possible), would you say it's illegal to use BX, for example, without having an AA, AB, AC, etc.?
John-Paul Belanger
Geometric Learning Systems
RE: Double datum letters
Nowhere the standard says that “you shall start with AA”.
I personally met people who believed that AZ should be followed by AAA, so actually explaining that “double alpha” means that AZ is followed by BA was absolutely necessary IMHO.
Frank
Frank
I'm thinking we all can agree with that (but I'm curious what your last post was alluding to, Frank).
John-Paul Belanger
Just that the order given as an example was, literally, required. There is a section in the standard that says something about "datum order is not required", that is what I go by.
Frank
On the side note, some companies (and possibly countries thru national standards) require using unique letters on datums, views and sections.
This means two things:
A. “single alpha” will be exhausted even faster.
B. skipping letters and burning alphabet from both ends should be tolerated.
However, I would say that not only is the letter irrelevant to the precedence of primary, secondary, tertiary, but that the letter itself could be plucked from anywhere in the alphabet.
I heard of one guy who always used his initials for the datums. Thus, no A, B, C, on the drawing anywhere. But the lone datum feature was labeled as D because his name was Daniel.
"Hey, Dan," people would say, "you can't do that."
"Yes I can," countered Dan, "see, it says here in the standard...!"
Needless to say, although he was right, he was kind of annoying :)
John-Paul Belanger
Frank
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Is the "note" on page 48 of the 2009 standard (at the end of paragraph 4.2) intended to be worded that way? I guess I understand the gist of it, but what is the deal with the first few words, "In the means this portion..."
I'm not an English major, but that seems like a typo or something.
John-Paul Belanger
-Dalai Lama XIV
