Rotomolded Insert Pull Out Forces
I am performing FEA on an assembly that includes rotomoldings with inserts. I have found some data
for pull out forces for injection molded inserts but not for rotomolded parts. I am thinking of using the injection molded data reduced by a fairly large amount to compensate for different materials and differences in material integrity.
Does anyone know of any pull out data for rotomolded inserts?
Jerzy
RE: Rotomolded Insert Pull Out Forces
You can only get this from the insert manufacturer. Inserts for roto-molding would be designed differently than those for injection molding. As such it is possible that they could be stronger.
