Limiting a left and right movement of a point located on a horizontal sketched curve line.
Hey all
I have recently learned about motion skeletons and how to use them.
I have a horizontal line representing a left and right path of a point. I want to be able to limit the distance that point can be moved when highlighting it and dragging it left and right. This point is a line segment end that in the motion skeleton is also defined as a pin location. I do not do any programming or much mathematical if then statements in ProE for such control. Any help would be appreciated
Norbert
www.weight-locker.com
http://www.linkedin.com/profile?viewProfile=&k...
RE: Limiting a left and right movement of a point located on a horizontal sketched curve line.
Yeah,
My suggestions were to split the Line using split point if you only wanted the point to move a certain distance on the line. However with Coincident or point on line in sketcher the point can travel further along or even off the line.
The >,< dim relations will give a warning if relation is violated but will not prevent it from happening but will pop up a message stating the relation that was valued.
Say your sketch dimension is sd6
Line 1| sd6 >= 2
Line 2| sd6 <= 10
As soon as the dim value goes outside range by modify or drag entity. You will get a message about the error
: Line # in section: Constraint has been violated.
/!\: Some constraint relations are no longer satisfied in S2D####.
The only way to forcefully maintain the limits is to use if then statements. Then is given by following line's equation.
Line 3| if sd6 < 2
Line 4| sd6=2
Line 5| endif
Line 6| if sd6 > 10
Line 7| sd6 = 10
Line 8| endif
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
