Toe board around fixed ladders
I am trying to determine if a toe plate is required at the base of a fixed ladder that is built into the hand rail at the edge of a platform. I have looked through OSHA 1910.23 which covers "Guarding floor and wall openings and holes" and 1910.23(a)(2) states
Every ladderway floor opening or platform shall be guarded by a standard railing with standard toeboard on all exposed sides (except at entrance to opening), with the passage through the railing either provided with a swinging gate or so offset that a person cannot walk directly into the opening.
I know that there shouldn't be a toe plate at the top of a ladder exiting onto a platform, but I'm not sure if it is required that there be one at the base of the ladder, below the first rung.
Thank you
Thank you
RE: Toe board around fixed ladders
However, you've got two dangerous extensions sticking out into the ladder guard to the right. See photo attached.
I can't tell enough about the geometry from the picture to tell if those extensions are problems are not. If the cage closes in to an 18" gap, they may just go over to the cage hoops.
