Threaded fastener calculations using ECSS-E-HB-32-23A
Hi all,
On a project I'm working on I've been instructed that our first approach to determining the MoS values on the fasteners in a design wasn't correct and told to use the ECSS document on threaded fasteners (ECSS-E-HB-32-23A). I'm trying to implement the method in a spreadsheet now but it's just not really "clicking" with me somehow, has anyone got any experience in using this handbook for fastener/ joint design and analysis? The document can be downloaded from this link here: htt ps://www.g oogle.ie/u rl?sa=t&am p;rct=j&am p;q=&e src=s& source=web &cd=1& amp;ved=0C CwQFjAA&am p;url=http %3A%2F%2Fw ww.ecss.nl %2Fforums% 2Fecss%2Fd ispatch.cg i%2Fpublic ations%2Fs howFile%2F 100171%2Fd 2010041613 5824%2FNo% 2FECSS-E-H B-32-23A(1 6April2010 ).doc& ei=TrItUvj KLsPC7AaY8 4CYBw& usg=AFQjCN GrzQsApA-y R5Svt8mU_D RhZBUXZg&a mp;sig2=d6 NwJyucdIrx kZHRXZ-EOg
Some (not many) of the chapters in the document have sample calculations in them which really helps to demonstrate the method but for the rest it just doesn't seem too clear, does anyone know perhaps where i might be able to read some previous examples of this method being used? Maybe a report of a previous design of a spacecraft/spacecraft's payload which used this standard for its joint analysis??
Any help would be greatly appreciated
RE: Threaded fastener calculations using ECSS-E-HB-32-23A
Anything specifically troubling you?
I think the part which I'm struggling with is the fact that so many of the calculations in the document rely on input data such as prevailing torque, allowable applied torque, friction coefficients for the threads and underhead contact area and other such bits of information yet the document only provides these data for a few specific applications. For example the maximum and minimum prevailing torque is only provided for fasteners which are M5, M6 or M8 in size and even then much of the data is missing (also the designs I'm working on involve the use of M3 and M4 screws for which there is no data at all given).
From searching online I've found a few different sources which provide some data for different fastener sizes/types but most of the time the figures from the various sources do not agree with each other. I think I would have much more faith in the calculations if I could rely on the input data I'm using. Is there a source of data (preferably an online one) for fasteners which I don't know about and is generally accepted by industry? If so I'd love it someone could point me in the direction of this source please!
