STEEL DESIGN
STEEL DESIGN
Hi all,
I'm new in staad, in steel design does staad design the connection ?
RE: STEEL DESIGN
Which version of STAAD are you using? If you're using STAAD.Pro v8i then surely it has a utility of CONNECTION DESIGN and it's really an excellent utility for 3D connection design. It has intuitive interface as well as tutorials in the help menu.
RE: STEEL DESIGN
RE: STEEL DESIGN
RE: STEEL DESIGN
http://julianh72.blogspot.com
RE: STEEL DESIGN
There is connection design option in STAAD called RAM Connection. I have just attached one image here for your reference only. I did a quick column to beam SP BCF type connection design. You can see from attached image that where connection design option is located.
