suitable hardenable filler spec for sleeve repair
HI,
ASME B 31.4 code Described “ A hardenable filler such as non-shrink epoxy or polyester resin shall be used to fill the void between the pipe and the repair sleeve “
Anybody can give me spec of non-shrink epoxy or polyester resin which should be used between pipe and sleeve
