heat exchanger
heat exchanger
heat exchanger
Hi guys, i am interesting to know in which case we should use the heat ex-changer in our chilled water system? please advise with small description on how the HEX is normally works.
RE: heat exchanger
Read forum policies.....
RE: heat exchanger
Hi willard3
excuse me i am new member in this forum. did i do anything wrong? please advise me?
i am still willing to learn about the HEX? please advise.
RE: heat exchanger
Read board policies which begin as follows:
>>>>>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be a substitute for appropriate professional assistance within your field or geographical region.
