ETABS 2013 ERROR - Running out of Memory
hi, i am facing the ETABS error which is 'ERROR IN DEFINING ANALYSIS MODEL ARRAYS. MAYBE RUNNING OUT OF MEMORY'.
Anyone facing the same problem?? have any solution for it?
Regards.
Thank you.
Regards.
Thank you.
RE: ETABS 2013 ERROR - Running out of Memory
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
What is the computer configuration? The machine satisfy the demand of the ETABS?
Also the operating system is important if is 32bits or 64bits, special if the model is complex.
If you need some help you can sent me the model and I can run on my computer.
Good luck!
