Legend of Line Types
Is there a method of adding a legend showing the line types used in a graph. I've attached a seive analysis program and want to add a legend for specd max and min and sample line types.
Dik
RE: Legend of Line Types
Point to a graph line with cursor and right-click (Series 1, for example), ADD data label, point and right-click again, FORMAT data label.
Umm. Yes. Use excel's legend feature.
Example attached.
Have I misunderstood the question?
If you want exact keystrokes, see help or at least tell us what version you're using.
(2B)+(2B)' ?
Thanks gentlemen... did all the heavy lifting... electricpete... if you had have moved the legend up, you would have completed it for me...
Again, thanks very much...
Dik
