Pipe Material substitution
Someone knows if it´s possible replace ASTM A-106 Gr. B by API 5L X-42 PSL-1, in a gas sour service.
Thanks for the help.
RE: Pipe Material substitution
Any code of construction apply? Is API pipe permitted? Nominal compositions reasonably close?
Mike
Are a gas separation facilities on production field, so all the pipeline are API but ISBL we will apply ASME B31.3.
israeljrr, it seems the API pipe would need to be a permitted material under B31.3. I am not familiar enough with either to say.
Mike
Anything is possible if the end user agrees to it. Why not ask them?
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
A106 is smls; X42 can be anything,
ASTM A106 is killed steel.
PSL 1 will not be killed steel. Therefore, you should consider PSL 2.
Over 30 years ago, a major gas producer/transporter specified X42 for sour gas service. Because even then steel manufacturers were making steel on a "one size fits all" basis, they actually recieved X58 equivalent pipe and failed to meet hardness requirements in the HAZ of the long seam and the circ seam welds. They ended up doing a whole lot of heat treating. I advised them that they needed to purchase this steel to a specified chemistry further limiting carbon, manganese, silicon, vanadium/niobium as my company was doing in similar sour service applications. So beware and act accordingly!!
I will say .. use API 5L pipe spec , but make sure you satisfy the wall thickness against ASME B31.8 ( gas line code).
API X42/X52 seamless pipe is industry acceptable ..... because you don't need any clad and get these pipes from a stockist easily .
