Import assembly into teamcenter. Use existing / Structure only
I have some problems with importing a assembly into Teamcenter.
Due to lack of time, we have ask e external company to make a assembly from existing parts we have already in teamcenter, and correct/clean up a few parts.
When i export the parts for that company a part with by example the name VNB12345 version 01.003 was renamed by teamcenter to VNB12345_01_003.
So the whole assembly they made have have wrong part-names, not corresponding with our names in Teamcenter.
The few parts they have changed i already have imported them into Teamcenter. That was no problem.
Now i want to import the assembly into Teamcenter with the "Default Import Action" option "use existing" for all the parts. I only want to import the assembly structure.
But when i do that the program still asks me to give a new/1 higher "Part revision" number for every part, and it gives me the possibility to give every part a new part-name. So it's still trying to import the parts instead of using existing parts in Teamcenter. And that's not what i want.
I want the option that i can say to use existing part VNB12345 version 01.003 in TC when it's trying to import part VNB12345_01_003.
Now part VNB12345_01_003 becomes part VNB12345_01_003 version 01.001.
Or when i rename part VNB12345_01_003 to VNB12345 TC makes it VNB12345 version 01.004
What am i doing wrong?
If i read other topics on this site i have to use "Default Import Action" option "use existing". And that's what i'm doing.
So next time we only ask the other company to correct/clean up the parts and make the assembly's our self. That's much easier than what we are doing now.
Hope someone can help me out with this.
Thanks already.
Thanks already.
Using NX 8.0 on Windows 7 (64)
