Pole shed diaphragm?
I have a 60'x150' pole shed project (19' to underside of truss) where the client does not want to provide an OSB or plywood diaphragm.
The system the client wants is pre-eng trusses at 4' o.c. (To match the poles) with 2x6 strapping at 24" o.c. and metal sheeting. This construction method is to apply to both the walls and the roof. The metal sheeting is NOT steel deck but more of a VicWest style architectural sheeting.
Has anyone here designed 2x6 strapping (or strapping in general) as a form of diaphragm?
We've determined that the sheeting may provide some form of diaphragm however we think that the weak link in the system will be the strapping, specifically the connection of the strapping to the trusses/poles.
Does anyone have any experience with this?
RE: Pole shed diaphragm?
backrun away from this one, and quickly, as he wants to be the engineer.Mike McCann
MMC Engineering
From the first minute I looked at it I knew it needed some sort of proper diaphragm, We can get away with no wall sheathing by using bracing but the roof needs something otherwise the columns would need to be considered cantilevers. Which then they fail miserably in slenderness.
Anyone besides Mike have another opinion? (Not a knock of Mike's opinion as I tend to agree with him)
However, with 19 foot eaves I think the forces will be too great to attain the economy of structure he is probably looking for, even with the poles at 4'.
Mike McCann
MMC Engineering
We don't mind the load going into the poles but we are more looking to be able to have the poles as fixed at the bottom and pinned at the top. For that I believe we need a diaphragm so the load can share across multiple poles.
Mike McCann
MMC Engineering
"We've been doing them this way for years! We're not putting sheathing on this thing."
They have jobs from years ago, with seals I might add, that have no sheathing and the columns are not overly sized. So either the previous engineers (yes plural) had a way of looking at the strapping as a pseudo-diaphragm or we're doing something wrong. Some of the older buildings that have been done were under the Farm Building Code (We're in Canada) which allowed for less stringent designs, however they removed that code from use and now these building fall under the National Building Code.
So can anyone think of a way that strapping could provide some sort of diaphragm action?
I will try to dig up the reference. We looked at a couple of existing buildings recently, no (reliable) diaphragm, no strapping. Just buried / cantilevered poles.
We've done some of these before but they were never this large. Mainly 12-15 feet tall and reasonable plan dimensions.
This way was also causing a cross moment being transfer by the trusses. So I had to state a minimum size and grade for the top chord and that the wind condition needed to be checked at a 1.25 (you may need a higher or lower factor for your case) factor inplace of the code 1.6 factor to allow the truss top chord to transfer this moment.
But as I stated I never finalized my calculation on these. So I could not say if the final numbers would give an answer I could seal. They were also for much smaller structures.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
And I didn't think the truss mfr would appreciate the loads we would be requiring them to resist.
Your issue is going to be finding the allowable capacity of the sheeting. It is not easy to get, but can be calculated. There is published literature available from the National Frame Builders Association.
the 2x6 strapping could be considered purlins and girts I guess. but it would be bending in the weak axis as the 2x6's are on flat.
It is generally just applied to give the siding something to be mounted to but we were looking into the probability of using it for some form of lateral load transfer/sharing.
If people think a sketch will help I can post one however it is basically a built-up wood column with a standard roof truss sitting on top. There is 2x6's on flat mounted horizontally on the wall between the columns at 24" o/c and on the roof perpendicular to the roof joists at 24" on centre. Nothing special.
I have seen allowable capacities with 29 ga that go upwards of 300 plf. As stated earlier, this requires very specific nail / screw patterns and sizes.
Mike McCann
MMC Engineering
Unfortunately, if I don't rely on it, I can't rely on any builders ever using me again :>
There is plenty evidence in our neck of the woods that it is pretty darn effective as a diaphragm.
Professionally speaking, I would not rely on it because at the first crinkle from contractors walking on it wrong, there goes any possible limited diaphragm action. To me, the stuff is just like aluminum foil.
As a side not, if this is the only work you have, you need to branch out in the market. Don't take me wrong here, but from your last comment, you appear to possibly be compromising your professional judgment to get work, and that is dangerous, very dangerous. If clients do not have enough money to do a job right, they will be the first to seek remediation from others, you in particular, when it fails. Be careful. Personally, I have been there and have had to walk away. The professional liability is just not worth it to me.
Mike McCann
MMC Engineering
I am pretty well diversified and walk away from plenty of jobs.
I don't feel that I am compromising my judgement. The 29 ga is not that bad. I always specify a screw pattern that is well in excess of that required for my limit of 100 plf. We just do not see these things failing very often here. I only do about one of these every couple of years and they are pretty small in height and footprint.
Also, how is a small crinkle going to affect the overall diaphragm strength? -we are talking shear, not standing on a beer can.
If it makes you feel any better, I do not do ANY work on mobile homes.
The city slicker headed into the country.
Of course that lead on a trail to the American Society of Agricultural Engineers, ASAE. Now Ag Engineers are different than Structural/Civil Engineers. A whole breed unto themselves.
Search them out you'll find papers on such subjects as;
Diaphragm Design of Metal Clad, Post Frame Rectangular Buildings ASAE EP484.1...this is actually a standard.
Characterizing Diaphragm Shear Stiffness for Diaphragm-Frame Interaction Amalysis ASAE Vol 32(5).
Pole Barn Wind Resistance Design Using Diaphragm Action ASAE Paper No: 75-4035
Strength and Stiffnes of Screwed Roof Panels for Pole Barns ASAE 1983.
Strength and Stiffness of Metal Clad wood freamed diaphragms CSAE...a Canadian equiv.
An Experimental Investigation of Diaphragm Behaviour of Farm Buildings ASAE 84-4511
Evaluation of Wood Frame and Metal Cladding in Roof Diaphragms ASAE 40(2).
Well there's a lot more like the above, but also,
Improving Resistance of Poles to Lateral Loads, ASAE Transactions 1981.
Design of Pole Foundations for Lateral Loads, Transactions of the ASAE 1981.
Performance of Pole Anchorages Under Gravity and Withdrawal Loads Transactions of the ASAE 1966.
All worth reading. But you would be best to head to the American Society of Agricultural Engineers, all the papers I have are old. Like me.
No doubt there is a lot of newer and more valuable updated stuff.
Good luck.
The spring stiffness would be adjusted (by iteration) to the point where the reaction at the top of the columns (The spring reaction) maxes out the shear capacity of the sheet metal. Our analysis goes as follows, the reaction at the springs would then be applied to the entire eave as a UDL. Then, the reaction on the end walls would be divided by the width of the building to determine if the linear shear exceeds the allowable load of 100 plf. Does this sound reasonable like a reasonable approach?
We think that this may be the most realistic way of looking at this as the sheet metal obviously provides some resistance and therefore acts as a semi-pinned support(maybe?). We also think that if the building starts to sway the purlins/girts (strapping) will provide some lateral resistance (perhaps not a quantitative amount but some none the less).
Further I have a couple other questions:
OHIOMatt/Everyone
What is the fastener and fastening pattern to achieve the 300 plf previously stated (roof cladding to strapping, strapping to truss)?
Everyone Else
How does the American code look at slenderness in this case (noted above)? In our initial runs in Risa we did not encounter any slenderness errors; we had expected to run into issues in this regard. In the Canadian wood code column slenderness cannot exceed 50. Assuming a fixed-free connection conditions (k=2) the slenderness ratio for a 4-2x8 going 19' works out to 63. Assuming a partially restrained-in-rotation top connection (k=1.5) and a fixed bottom connection the slenderness ratio is 47 and therefore it appears we can get a reasonably sized column to work.
Any of your thoughts and suggestions are much appreciated.
Sorry, but I will never rely on the 29 gage material at the roof.
Mike McCann
MMC Engineering
1. The building is fairly large, the one-time cost of pile driver mobilization can be "absorbed" more easily than on a smaller structure.
2. Installation of the "poles" will be quick which will hold down labor costs when compared to a more sophisticated design.
3. You should be able to accommodated the clients "special" requirements.
Perhaps pile driving is not common in your area... in which case please ignore. Where I am, driven piling would really be a potentially viable solution (both technically and financially).
www.SlideRuleEra.net
www.VacuumTubeEra.net
