Part Familt - Replace componet dialog Chose Family Member window
I am using a team center environment and I need to see a part attribute in the list of ways to filter a part family and select it members inside the replace component dialog. Now this works great for attributes that are defined by the part family but how to i bring in attributes stored against the part but not created by the part family itself.
The attribute I want to see (material) is not one that I want to define when I create the part family. It is an attribute in a form for each part.
Is there a way to get this to happen?
RE: Part Familt - Replace componet dialog Chose Family Member window
Are you sure you have attached the correct image you intented to? :) I can see only a closed corner customer default page.
Best Regards
Kapil Sharma
