Tubing Weld Repair Procedures
Our welders have been TIG repairing damage (corrosion and physical) on some of our high, medium and low pressure process tubing, alloys welded were AA5000 series Al, Cres 300 series and Inconel 625. Fuilds are hydraulic fluid, and #2 fuel oil. They are certified for 1/8" plate SST and AL all position. They use the damaged area size dictates repair methods (metal build up, patch or section replacement). The tubing is test to the new tubing requirements (proof pressure test, flush, and systen checkout). They asked me to document the repairs w welding procedures.
I was thinking about
1. Remove tubing section
2. Clean
3. Repair (TIG) damged area governs repair method
a. Pin hole <.25" clad repair
b. area >.25" and <1/2 tube dia - over lay patch same thickness as tubing
c. area > 1/2 tube dia - cut out section to clean metal, replace removed section and butt weld
4. Pressure test
5. Flush/clean
6. Reinstall
7. Leak test system
What are other required parameters for this type of procedures or thoughts?
2. Clean
4. Pressure test
5. Flush/clean
6. Reinstall
7. Leak test system
RE: Tubing Weld Repair Procedures
http://www.youtube.com/watch?v=ppXRMTeR2NQ
That video is scary, Its like doing a rain dance over a hand grenade with the pin pulled. All they need is a little air pocket in there.
B.E.
You are judged not by what you know, but by what you can do.
Either cut out a portion or replace a section of pipe would be my vote.
I am glad to see that you at least have a process for this.
Plymouth Tube
There can be a lot of trash in the bottom of oil lines.
I have seen where people have used any old plastic or rubber under clamps to protect the pipe, and in the process picked something very high in Cl and assured that the pipe would corrode under it.
Plymouth Tube
