kingsoft spreadsheets
The company I work for is trying to get by with using Kingsoft spreadsheets saved in .xls format. However Catia will not read these spreadsheets on systems that have Kingsoft loaded. Does anybody know how to get catia to read these.
RE: kingsoft spreadsheets
You can try to use txt format instead of xls, Notepad is existing by default on any Win OS.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
When I tried to import a text file it gave me an error message that no data was contained in the file or file not found. It did load it in the tree and when I go through edit table everything is there. This is the same message I get with the excel docs.
KR
