combining pumps
combining pumps
we have at my work place pumps that have different outlet pressure, 11 bars and 8 bars pumps
I want to know if there is a methode to combine the pumps together (parallel) in the same pipeline
RE: combining pumps
Assuming that you are referring to centrifugal pumps, the head/ capacity curve for a centrifugal pump is supplied by the pump manufacturer. The curve describes the relationship between the head and capacity of the particular pump. As you look at the curve, note that the BEP (best efficiency point) is located somewhere between 80% and 85% of the shut off or maximum head. To maximize the life of the pump you should operate the pump as close to the BEP as you can.
If the pumps are running at the same time, the capacities are additive at the same head. The resultant curve gives a new intersection point on the system curve for the combined capacity.
With parallel pumps with different pressures, you will not be operating the pumps at the BEP. Running different size pumps in parallel is probably not a good idea because the larger pump will cause the smaller pump to be throttled forcing the smaller pump to run too far off of the BEP. This can cause shaft deflection and possible premature bearing and seal failure.
Refer to the attached article.
http://www.mcnallyinstitute.com/15-html/15-01.htm
RE: combining pumps
However in direct answer to your question the answer is yes, but would require your 11 bar pump to be throttled to reduce its pressure to something similar to the 8 bar pump. Due to the extra friction effects, it is likely that neither pump will operate at its"rated" flow, but by some experiment by reducing the pressure from the higher pressure unit, you will find the optimum flow which allows both pumps to work to their best efficiency and capacity.
Give us some more details about the pumps and system and you'll get a lot more back. Details such as flow, power, pipe size, static h head, flow diagram, things like that...
RE: combining pumps
How can the 11 bar pump be throttled to reduce its pressure to be close to 8 bar?..I'll provide more details as soon as possible
RE: combining pumps
More details would be good.
RE: combining pumps
Throttling as LittleInch suggests is intended to reduce the pressure after the control valve to a value matching the discharge pressure of the "8 Bar" pump at its operating point. Depending on your actual requirement, "control valve" can be anything from a full control valve with the ability to automatically adjust the downstream pressure of the "11 bar" pump, or a manual valve you can adjust and leave, or even a restriction orifice if the pump doesn't have other duties to perform.
RE: combining pumps
RE: combining pumps
If each pump had a BEP at the resultant individual flows in each pump, of the combined flow through the system, then each pump would operate at their individual BEP.
In other words...
If the designer had enough forethought to simulate these pumps using curves without the BEP points marked, s/he would see the flow in each pump and the head produced by each pump and could then order each pump with the exact BEPs corresponding to the head and flow seen in each pump during the simulation.
Independent events are seldomly independent.
RE: combining pumps
RE: combining pumps
It is going to be very unlikely that either pump will be at the BEP or indeed the "rated" flow as most of these options ignore the increased head loss through the system. Some person sees a "500" gpm pump and a "400" gpm pump and thinks Ah ha I can get 900 gpm.... Errr
RE: combining pumps
yeah that's exactly true. We already have those pumps and we have a duty that neither pump could handle alone
I apologize for the lack of information. I can't provide them now. maybe in two or three days.
and thank you for the help
RE: combining pumps
RE: combining pumps
RE: combining pumps
RE: combining pumps
RE: combining pumps
