Sketch line on flat pattern
What's the best practice way to make a sketch line visible on a flat pattern?
I want a line on there which will be used for engraving.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: Sketch line on flat pattern
You can select the supporting curves while doing the flat pattern itself (sorry i have not checked it in NX7.5 though but you can check).
I am attaching an image herewith.
Best Regards
Kapil Sharma
One more question: Where can I change the line color?
The supplier wants us to color engraving lines yellow.
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
If you go to the flat pattern style, under the tab "flat pattern" you have to change the color of "added top"
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
