The big difference interpass temperature beetween Root pass and Fill Pass
when we qualify PQR, we will record all the value of interpass in all pass (Root, Hot, Fill, Cap). We will choose the biggest value among all the value (called A) According to ASME IX, in WPS we will add more 56 degree to this biggest value of interpass, so Maximun interpass temperature in WPS is A + 56. This value of interpass will be used in all pass in WPS (Root, hot, fill, cap).
There is one thing I'm not clear : For example, in root pass while qualify PQR,I have interpass temperature 80 degree. Fill pass I hvae interpass 200 degree. So WPS will have interpass 200+56 = 256 degree for all pass. In production weld, my welder performs Root pass with interpass 250 degree. It far over 80 degree in comparision with qualify PQR but is still in the range of WPS. So the quality of root pass is affected or not. There is something unreasonable here or not.
The big difference interpass temperature beetween Root pass and Fill Pass affects the quality of weld joint or not?
RE: The big difference interpass temperature beetween Root pass and Fill Pass
If the production weld does not require impact testing, you need not be concerned.
Finally, the interpass temperature does not apply to the root bead per the definition of interpass temperature in ASME IX and the definition of "Pass: a single progression of welding or surfacing operation along a joint, weld deposit or substrate. The result of a pass is a weld bead or layer."
