Using multiple reducers
Any guidelines on using multiple reducers for drastic line size changes?
Example 8"x2". I would go 8"x4" and 4"x2". Is this OK or are there specific rules to follow.
Thanks.
Thanks.
RE: Using multiple reducers
The ycan look quite odd, especially if you've got eccentric reducecers, but it's allowable.
For really big changes (say 16 x 2) you could use tees, but it is fairly rare to go for that sort of size change.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
