torque-roll-axis calculation
Good Morning All,
I am trying to calculate the torque roll axis for a powertrain system. After some research I know that the the calculation is only dependent on the moment of inertia and also after further research I have come across multiple papers from Singh (and referenced by almost everyone) which is the photo listed above. I have created some matlab code in trying to calculate the TRA direction but don't seem to be obtaining the right values. I was wondering if anyone could tell me where I am going wrong or have any other reference that I could perhaps follow.
I have the following inertia matrix (M_theta):
I=[2.519 4.458 4.409 -.1678 .5385 -.0947];
and should receive TRA_Direction as: [0 0 0 .992113 .0347851 .120426] but I do not. Is there anything that I am missing here when normalizing the first column or taking the inverse?
function[TRA_Direction]= TRA_Direction(I)
% User Input
% I: Moment of Inertia Matrix expressed as [Ixx,Iyy,Izz,Ixy,Ixz,Iyz]
% Output
% TRA_Direction: The Direction of the TRA
%Mass Inertia Matrix
M_Theta=zeros(3,3);
M_Theta(1,1)=I(1);
M_Theta(1,2)=-I(4);
M_Theta(1,3)=-I(5);
M_Theta(2,1)=-I(4);
M_Theta(2,2)=I(2);
M_Theta(2,3)=-I(6);
M_Theta(3,1)=-I(5);
M_Theta(3,2)=-I(6);
M_Theta(3,3)=I(3);
Inv_M_Theta=inv(M_Theta);
a=norm([Inv_M_Theta(1,1) Inv_M_Theta(2,1) Inv_M_Theta(3,1)]);
Torque_Axis=[1 0 0];
Theta_TRA=a*Inv_M_Theta*Torque_Axis';
TRA_Direction=[0 0 0 Theta_TRA']';
RE: torque-roll-axis calculation
It seems to me there are four broad possibilities for error
1) Singh is wrong
2)your mental interpretation of Singh is wrong
3)your matlab interpretation of 2) is wrong
4)your example is wrong (I am confused to see both positive and -ve cross terms)
I'd add that in practice ignoring the contribution of the powertrain mounts is a bit odd.
Cheers
Greg Locock
Cheers
Greg Locock
Thank you though,
Mel
Cheers
Greg Locock
