Interpreting Geotech Report for Allpile Input - Modulus of Subgrade Reaction (kcf)
I am determining the embedment for W6x9 piles to resist lateral loads in the range of 1.25-1.5kips to support a solar structure. We typically do our own soil testing on site, however this project is unique. The geotechnical report provides a "Modulus of Subgrade Reaction (kcf)" in the range of 60-200+ in multiple borings. I am using Allpile 7 for analysis. The lateral analysis input for Allpile is "K" which is the modulus of subgrade in units of (lb/in^3) and "e50".
The input for K is in the range of 0-2000 lb/in3. If the geotech report provides "Modulus of Subgrade Reaction" of say 60kcf --> 60 x 1728 = 103680 k/in3 --> 103,680,000 lb/in3. I'm not a geotech guy, therefore this doesn't make much sense to me.
Ultimately, what shall I input into Allpile for K - modulus of subgrade (lb/in3) when given Modulus of Subgrade Reaction (kcf) from a geotech report of say 60? Thanks so much for your help!
-Nick
RE: Interpreting Geotech Report for Allpile Input - Modulus of Subgrade Reaction (kcf)
Interesting that someone can take a value for the vertical deflection of a 30" diameter plate on a roadway subgrade and apply it to the lateral resistance of a pile under lateral load. Wishful thinking.
isn't 60 k/ft3= 60/1728=0.0347k/in3=35lbs/in3 ?
just saying,
How do you like using ALLPILE? It looks like it performs the same lateral analysis as LPILE but easier to use and perform a lot more. I'm also a structural engineer and I'm starting a new job with a solar company and I'm trying to determine what is the best software for pile design.
Obviously missed this post originally.
Just another expample of someone using software without understanding the input values.
Garbage in = garbage out has never been truer.
Mike Lambert
At the risk of sounding jerky, which I do a lot anyway, instead of posting a question to a bunch of strangers on a message board (a very good message board mind you), why not just call the geotech who wrote the report and ask them for this information or a clarification? Tell them you are a structural engineer and not a geotech and they will help you. This is what a consultant team is for. In my pile experience (as a structural engineer), I gave the geotech the loads and they designed the pile capacity (of the soils).
But I do agree with the other posters, you should be careful using software to solve a problem you do not completely understand.
Also, not having designed anything like that in a while, and not knowing your soil types, 1500lb applied at the ground surface to a W6x9- I am guestimating 10ft embed? Wait- do you have uplift too?
Steel piles for a solar panel structure? It would seem like shallow auger cast concrete piles may be a better option. Maybe you are extending these up to be the columns also, which would make sense.
