Journal: Getting component and edges from point
I am trying to figure out how to get the component and edges from a point. For this journal it will have you select a corner point on a body, and from there; I plan to use the component the body is under and the respective edges from that corner to move it. I need the edges to create a csys(I have code for), I don't have code for selecting the edges. Thanks in advanced!
Denis Huskic
Data Prep NX7.5
Kettering University
Class of '17
RE: Journal: Getting component and edges from point
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Dim theSession As Session = Session.GetSession() Dim theUI As UI = UI.GetUI() Dim theUfSession As UFSession = UFSession.GetUFSession() Dim lw As ListingWindow = theSession.ListingWindow Dim pickedPoint As Point Dim myModelingTolerance As Double Sub Main() theUfSession.Modl.AskDistanceTolerance(myModelingTolerance) Dim workPart As Part = theSession.Parts.Work lw.Open() Dim myPointTag As Tag If Not select_point("Select Point", myPointTag) = UFConstants.UF_UI_OK Then Exit Sub End If lw.WriteLine("pickedPoint: " & pickedPoint.Coordinates.ToString) AskParents(myPointTag) End Sub Sub AskParents(ByVal objTag As Tag) Dim n_parents As Integer Dim parentTags As Tag() Dim myPoint As Point Dim myEdge As Edge Dim myXform As Xform Dim myTaggedObject As TaggedObject myTaggedObject = Utilities.NXObjectManager.Get(objTag) If myTaggedObject.GetType.ToString.ToLower.Contains("point") Then myPoint = myTaggedObject lw.WriteLine("the tagged object: " & myTaggedObject.GetType.ToString) lw.WriteLine("") Try theUfSession.So.AskParents(objTag, UFConstants.UF_SO_ASK_ALL_PARENTS, n_parents, parentTags) lw.WriteLine("num parents: " & n_parents.ToString) For Each parentTag As Tag In parentTags Dim parent_object As TaggedObject = Utilities.NXObjectManager.Get(parentTag) AskParents(parent_object.Tag) If parent_object.ToString.ToLower.Contains("edge") Then myEdge = parent_object lw.WriteLine("") lw.WriteLine("edge type: " & myEdge.SolidEdgeType.ToString) lw.WriteLine("edge length: " & myEdge.GetLength.ToString) lw.WriteLine("edge owning part: " & myEdge.OwningPart.FullPath.ToString) Dim partTag As Tag = myEdge.OwningPart.Tag Dim occTags() As Tag theUfSession.Assem.AskOccsOfPart(Tag.Null, partTag, occTags) lw.WriteLine("number of occurences: " & occTags.Length.ToString) For Each temp As Tag In occTags Dim myComp As Assemblies.Component myComp = Utilities.NXObjectManager.Get(temp) Dim myCompPos As Point3d Dim myCompOrientation As Matrix3x3 myComp.GetPosition(myCompPos, myCompOrientation) lw.WriteLine("") lw.WriteLine("component name: " & myComp.Name) lw.WriteLine("component display name: " & myComp.DisplayName) lw.WriteLine("distance from picked point: " & MeasureDistance(pickedPoint, myComp).ToString) If MeasureDistance(pickedPoint, myComp) < myModelingTolerance Then lw.WriteLine("** This is the component that was picked **") End If lw.WriteLine("") Next lw.WriteLine("") End If Next Catch ex As Exception ' NXOpen.NXException: Current object is not smart lw.WriteLine(" Error: " + ex.Message) lw.WriteLine(" " & myTaggedObject.GetType.ToString) End Try End If End Sub Function select_point(ByVal cue As String, ByRef pt_tag As Tag) As Integer Dim base_pt As Double() = New Double(2) {} 'Dim point_tag As NXOpen.Tag = NXOpen.Tag.Null Dim response As Integer = 0 Dim base_method As UFUi.PointBaseMethod = UFUi.PointBaseMethod.PointEndPt theUfSession.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM) theUfSession.Ui.PointConstruct(cue, base_method, pt_tag, base_pt, response) theUfSession.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM) Dim pointLocation As Point3d pointLocation.X = base_pt(0) pointLocation.Y = base_pt(1) pointLocation.Z = base_pt(2) pickedPoint = theSession.Parts.Display.Points.CreatePoint(pointLocation) 'pickedPoint.SetVisibility(SmartObject.VisibilityOption.Visible) Return response End Function Function SelectPointObject(ByVal prompt As String, ByRef selPoint As Point) As Selection.Response Dim selObj As TaggedObject Dim theUI As UI = UI.GetUI Dim title As String = "Select a Point" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_point_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selobj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then selPoint = selObj Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function MeasureDistance(ByVal obj1 As DisplayableObject, ByVal obj2 As DisplayableObject) As Double Dim result As Double Try Dim nullNXObject As NXObject = Nothing Dim measureDistanceBuilder1 As MeasureDistanceBuilder measureDistanceBuilder1 = theSession.Parts.Display.MeasureManager.CreateMeasureDistanceBuilder(nullNXObject) measureDistanceBuilder1.InfoWindow = False measureDistanceBuilder1.Mtype = MeasureDistanceBuilder.MeasureType.Minimum Dim nullUnit As Unit = Nothing Dim measureDistance1 As MeasureDistance measureDistance1 = theSession.Parts.Display.MeasureManager.NewDistance(nullUnit, MeasureManager.MeasureType.Minimum, obj1, obj2) result = measureDistance1.Value 'measureDistance1.Information() measureDistance1.Dispose() Catch ex As NXException MsgBox(ex.Message) Return Nothing End Try Return result End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination End Function End Modulewww.nxjournaling.com
