Frequency Response Restart From SOL 103 to SOL111
Hi all, bigears
Aomebody knows what is wrong in the following restart?
The error is the following:
*** USER FATAL MESSAGE 2134 (GP3)
LOAD OR DEFORM SET 1 DEFINED FOR BOTH GRAVITY AND NON-GRAVITY LOADS.
*** USER FATAL MESSAGE 4390 (LCGEN)
LSEQ ENTRY 1 REQUESTED VIA LOADSET DOES NOT EXIST IN THE BULK DATA
*** SYSTEM FATAL MESSAGE 3001 (GP4)
and the .bdf files are:
$ NASTRAN input file created by the Patran 2012.2 64-Bit input file
$ translator on September 02, 2013 at 17:26:30.
$ Direct Text Input for Nastran System Cell Section
NASTRAN SYSTEM(316)=19
$ Replace the 19 in the above line with 7
$ to get a restart DBALL instead of what is currently written
$ Direct Text Input for File Management Section
$ Direct Text Input for Executive Control
$ Normal Modes Analysis, Database
SOL 103
TIME 1
CEND
$ Direct Text Input for Global Case Control Data
TITLE = MSC.Nastran job created on 19-Aug-13 at 14:17:13
ECHO = NONE
RESVEC = NO
SUBCASE 1
SPC = 2
LOAD = 2
VECTOR(SORT1,REAL)=ALL
SPCFORCES(SORT1,REAL)=ALL
$ Direct Text Input for this Subcase
SUBCASE 2
METHOD = 1
SPC = 2
STATSUB = 1
BEGIN BULK
$ Direct Text Input for Bulk Data
PARAM POST 0
PARAM PRTMAXIM YES
EIGRL 1 1. 3. 20 0 MASS
Herne nodes and elements with properties
$ Loads for Load Case : self_weight
SPCADD 2 3
LOAD 2 1. 1. 1
$ Displacement Constraints of Load Set : embedment_1
SPC1 3 123456 2282 2293 2304 2347 2377 2490
2508 2532 2543
$ Loads for Load Case : modes
$ Gravity Loading of Load Set : gravity
GRAV 1 0 9.81 0. -1. 0.
$ Referenced Coordinate Frames
CORD2R* 1 .5 3.56299996376038
* -2.6329998970031.5 4.99146485544201-6.8564044455391
* .5 7.78640451229634-1.2045350053215
CORD2R* 2 .5 .633000016212463
* -3.6240000724792.5 -.55652864381755-.10702871218870
* .5 -2.8839711227845-4.8135287325092
ENDDATA 488e9eac
and the modified .bdf file is:
$ translator on September 03, 2013 at 18:32:42.
$ Frequency Response Analysis, Modal Formulation, Database
ASSIGN MODES='modes103.MASTER', old $ Reference
RESTART LOGICAL=MODES VERSION=1,KEEP
SOL 111
TIME 1
CEND
ECHO = NONE
RESVEC = YES
LOADSET = 1
SUBCASE 1
SUBTITLE=modal_freq_response
METHOD = 1
FREQUENCY = 1
SPC = 2
DLOAD = 2
DISPLACEMENT(SORT1,REAL)=ALL
ACCELERATION(SORT1,REAL)=ALL
BEGIN BULK
PARAM POST 0
PARAM PRTMAXIM YES
FREQ1 1 0. .15 10
$ Loads for Load Case : modal_freq_response
SPCADD 2 1
RLOAD1 4 5 2
LSEQ 1 5 3
DLOAD 2 1. 1. 4
SPC1 1 123456 2282 2293 2304 2347 2377 2490
2508 2532 2543
$ Distributed Loads of Load Set : wind_field
PLOAD1 3 1640 FZE FR 0. -20. 1. -20.
PLOAD1 3 1641 FZE FR 0. -20. 1. -20.
PLOAD1 3 1642 FZE FR 0. -20. 1. -20.
PLOAD1 3 1643 FZE FR 0. -20. 1. -20.
more of the same, PLOAD TO MORE ELEMENTS
$ Referenced Dynamic Load Tables
$ Dynamic Load Table : wind_force
TABLED1 2
0. 1. 1.5 1. ENDT
ENDDATA 56c88844
I can´t find the error.
Best Regards
