AWS CODE.
AWS CODE.
what is the given period needed to requalify a welder.
RE: AWS CODE.
In the first case; welding standards do not place a time limit on the time needed to weld the test coupon. Some companies may impose a time limitation, but that isn't a code requirement.
In the second case; most AWS welding standards allow the welder's qualification and certification to be "extended" indefinitely if the employer can show continuity.
Best regards - Al
RE: AWS CODE.
