Why Force is not considered by software during modal and frequency response analysis
Is there any specific reason behind , the analysis software is not considering the force if they are applied in any specific nodes. But they consider forces in static analysis.
Is there any other way to consider that force in modal and dynamic analysis
Appreciate your comments
RE: Why Force is not considered by software during modal and frequency response analysis
In a static analysis, you may apply a load to a part/assembly and determine deflections, stress, strain, reactions forces, etc.
Brian
www.espcomposites.com
But ,It is possible to make a response analysis (Frequency response for my study) in which we can make a function( force vs frequency) and input at the desired point. Right?
In brief, my case has to be excited with a vibration at component fixing point and this force has to be applied at a specific node . Stress has to be observed as output for a limited frequency range
http://julianh72.blogspot.com
Cheers
Greg Locock
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
