How can this system work...
Dear all!
A simple problem (it's not a homework I promise!).
I have
4 x 12V 85Ah batteries.
1 x 12V 85W solar panel
2 x 12V solar charge controllers
1 x 24V solar charge controller
How can I power a system with 24V night and day assuming the power consumption of the system is not draining much power. I unfortunately cannot change the solar panel.
Thank you in advance, and looking forward to hearing from you soon!!!
RE: How can this system work...
Short of some way of switching a single 12V charge controller frequently back and forth between the two two-battery banks, I see no way to solve this with out further purchases.
A scheme that switches the charge controller output back and forth between the two two-battery banks in parallel, about every 5 minutes, all solar day, would be needed.
Otherwise use a (new)step-up charger that can take the 12V from the panel and and charge a 24V battery bank. Or procure another identical panel and use one panel to charge one battery and the existing one to charge the other battery - each using one of the two existing 12V charge controllers.
Keith Cress
as keith says, or similar:
do we assume the 85w solar panel is enough to power your 24v load? if so, do we assume avg load is about 30watt or 1.5amp #24vdc?
then use 1 batt, 1 12v charger, and 1 12v->24v converter like:
http://www.secamerica.com/products/converters/620....
or give more details :)
Thank you very much for the answers.
I will try the step up transformer! I hope it works!!!
Your converter seems a bit thin for this application. I would have expected something along the lines of 8.5 A charging current. The 85W panel is only going to produce about 3.5 A on a good day, but your converter is limited to 3A. You've never stipulated your power draw, so that would subtract from your charging rate. Even ignoring that, a fully depleted battery could potentially 5 days to fully recharge.
TTFN
I'm planning on installing the step up after the batteries... to power my system, which draws around 1A of current
