Fired Heater Vertical U tube Hydrotest
I have a question regarding hydro testing of vertical radiant tubes of fired heater.
The U tubes are being welded with the manifold and the manifold itself is in 3 pieces which is being welded at site also. After all welding activities are done the manifold circumferential joint and the joint between the manifold and the tube need to be tested. Note that there is no drain at the bottom of U tubes.
So my question is that if we fill the manifold and tubes with water then how do we empty the whole assembly? and then after emptying the whole assembly still there will be some water inside the tubes and manifold, so how to make sure that the whole assembly in completely dried from inside.
RE: Fired Heater Vertical U tube Hydrotest
