Flippin' Angles ; )
Flippin' Angles ; )
Flippin' Angles ; )
Hi all,
Since we updated from NX4 to NX7.5 drawings in our system have had some of the angles flipped, ie a 20deg angle will now be 160deg. I see this mostly on hole centerlines dimentioned fron section lines.
Any one else had this issue? is there a fix?
Cheers,
Rich
RE: Flippin' Angles ; )
Hi.
We had the same issue when we refiled from NX4 to NX6. The "bug" is in the versioning in Drafting preferences.
"Version Up all Drafting Objects and Memberviews" (not exactly sure about this exact name because I have NX8.5 now) will cause this behaviour.
You should disable that (customer defaults or env file) or set the filters to exclude Angular dimensions.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
Thanks Ronald,
I will pass on your info.
