How can to weld CuNi to Carbon Steel (API 5L X52)
Hi friend,
I have to weld CuNi to Carbon Steel (API 5L X52), Butt weld, thickness 5-7mm.
Which is welding consumable?
Which is Process (GTAW or Brazing..)
Which is parameter (Heat treament, Pre-heat.....)
Pls give me advice.
Pls give me advice.
RE: How can to weld CuNi to Carbon Steel (API 5L X52)
Best regards - Al
Is the joint configuration amenable for brazing?
