Question about associativity between copied .prt files?
I wanted to change one part, so I`ve created a new folder, after that I`ve copied the file, renamed it and then i had 2 different files in different folders, with the same parts inside. Then i changed some features in the tree of the the second part. Surprisingly for me in assembly in witch the first part was assembled I saw that the part has changed. Could somebody explain to me why there is a relation between copied files with different names? How that associativity works in NX?
RE: Question about associativity between copied .prt files?
Hi Nick,
i hope you have not used a SAVE AS operation in context of the assembly to make a copy of your original part.
But if you have just copied the file and pasted into another folder (also renamed it) then i see no reason why this happened.
Can you please share some supporting images (am not sure if you can share the parts and assembly also)? I amy be missing your point.
Best Regards
Kapil Sharma
now when I think.... may be I used save as...
While the Assembly file may have a different name and therefore is considered a different model, the components haven't change and are simply shared by BOTH assemblies. Therefore, hanging one of the component parts can potentially effect BOTH assemblies.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
