Galvanized and Stainless Steel Bolts Interaction
I am working on two projects that I am debating the use of Galvanized steel plates and Stainless Steel Bolts.... Both cases will be considered marine and will be in cyclic conditions of wet/dry.
1) Wet, exposed, bridge. I want to use 1/4" plate connections with stainless through bolts to timber members. I have experienced overly rusted bolts and compromised timber in the past but the plates hold up quite well...
2) similar to first only more complex structure and now we introduce the presence of chlorine (like heavily chlorinated pool water)
... So any issues with material interactions that I am not aware of, or something i can specify to eliminate said interactions? and does the presence of chlorine effect the annodic-cathodic relation ship?
Both of these are large projects and the use of epoxy coatings will destroy the budget and the owner would rather just invest in a more routine maintenance program... but we all know how those maint. programs go.
Thank you for any advice/knowledge
RE: Galvanized and Stainless Steel Bolts Interaction
For case 1) you may want to consider hot dip galvanized fasteners, depending on a lot of variables such as maintenance procedures, joint details, etc. Here are some links with more information:
http://www.nickelinstitute.org/~/Media/Files/Techn...
http://www.hdgasa.org.za/Journals/indSearchs/B/Bol...
http://www.galvanizeit.org/images/uploads/publicat...
http://www.standard.no/PageFiles/1194/M-001.pdf
If you decide to use SS, you will need Type 316 (ASTM A193 B8M), also known as A4 according to ISO 3506-1.
For case 2) you will need to look into more highly alloyed grades of SS than 304 or 316. I doubt that galvanized steel plates will be sufficiently corrosion resistant:
http://www.bssa.org.uk/topics.php?article=18
http://www.imoa.info/moly_uses/moly_grade_stainles...
The second project is for a facility in which my firm has done annual inspections for 15+ years. The structures all utilize painted galvanized plates. The history has shown that the maint. routines of repainting the plates works well and is far cheaper than special alloys. the plates are typically oversize allowing for a large amount of rust before ever compromised. And in reality i would say the most i have seen in area loss to be within less than 5% initial. The bolts however.... they are horrible i have hit one with a hammer and it fell out, the middle of the bolt was being held together with a strand of rust no X-section area.
I am guessing the ongoing maintenance allows the plates to last, but the environment within timber members deteriorates the bolt (hence using SS)
What I was planning, and please throw me under the bus if this is a worse idea than all galv. connections, just A36 HD Galv plate with epoxy paint coating with Stainless Steel, Type B8, Class1, AISI 304 bolts... most are 5/8-3/4" but the first job will have some 1"+ for the heavy timber...?
Richard
Have you considered other alloy bolts: e.g., aluminum bronze, K Monel, 17-4 PH, etc. Also were the original steel bolts bare or galvanized? If bare, consider galvanize.
We tend to spec ASTM A153 for structural nuts and bolts. We also have an additional requirement if "cold galv" (paint) is used for repair of any galvanized items: a minimum of 94% metallic zinc by weight in the dry film. There are at least 3 common brands which can meet this spec, I think ZRC is the most common - and they have both shiny and dull grey formulations.
ASTM reduced their minimum metallic zinc requirement some years ago for these repair paints, but our in-house testing showed better performance with the 94% minimum.
American Galvanizers Association
Galvanizing Insights Volume 8 Issue 2
http://image.exct.net/lib/ff3716717460/d/1/Dr%20Ga...
I am still debating on requiring an insulating buffer washer but i think it is a pointless expense as the bolt will always come into contact with the steel plate during install...
Thanks for the resources and helpful info, you have swayed me to look into this further!
If this is a heavily chlorinated environment with any organics (like in a pool) you will get volatile chloramines.
These will cause SCC of stainless at ambient temperatures.
If you want more info look into the history of swimming pool roof failures.
Never use SS in stressed locations above pools (or any chlorinated water in an enclosed situation).
Plymouth Tube
Would you recommend just sticking to all HD Galv bolts? I guess I know any application will result in metal failures and deterioration i am trying to determine which one is better in a length of life.
Thanks again everybody!
HD galv is likely the cheaper choice, and may well work "well enough"
I was hoping SS bolts would be a magic bullet since the existing galv. bolts are in horrible shape.
Rain is good, it washes away crap that settles, especially near salt water.
You might want to look and make sure that you don't have places that can trap water though.
How the joints are made up can matter, often it is scuffing from tools or nuts (or bolt heads) turning against plates that scrape the Zn and create places that start to rust first.
Plymouth Tube
They are about the same price as 316, but much stronger.
While they have similar crevice corrosion resistance to 316 they do have significantly better SCC resistance.
Grades like 2101, 2003, 2102 are becoming more popular for rebar, but they haven't worked into hardware like you are using yet.
The traditional duplex, 2205 is more expensive but it has higher corrosion resistance.
Plymouth Tube
http://www.fera.org.uk/pdf/Fera%20seminar%202%20Fe...
http://www.bumax.se/wp-content/uploads/2013/06/BUM...
