Which of the two Saddles shall be sliding one in horizontal Vessels,
Hi All,
I would like to ask that what is the criteria of choosing the "Sliding Saddle" that is which one shall be sliding saddle. Can I choose any or it depends upon the process requirement (like inlet nozzle or outlet nozzle location).
thanks
IAK
RE: Which of the two Saddles shall be sliding one in horizontal Vessels,
This is generally a choice/decision that the piping stress group would have significant input on. Ask them.
Typically, the saddle that is the one configured for movement is the one OPPOSITE the one closest to the HX channel.
On the ultra-common TEMA BEM HX, it makes no difference...
Yes like TGS4 says, ask pipe stress guy. You can arbitrarily assign to either one and put a "Hold" or " To be confirmed" in the beginning. Eventually, pipe stress guy shall tell you where they want after they run the stress analysis.
If you are fab. Slot both sides and let the installer choose its side.
