Flow Simulation
Flow Simulation
Hello All,
I'm back with more question(s). I just started to learn Flow Simulation. I been viewing many videos on this topic and have almost completed by first project, however. "That's Why I'm here!" I come up with a message when running the project for Results. Here it is.
It is not possible to calculate the internal task, if there are mass/volume flow openings but no pressure boundary conditions defined.
I've attached an E-Drawing as well as a screen shot to hopefully help.
Thanks in advance. I'm sure this will not be enough info
KenJG
KenJG
RE: Flow Simulation
What is your question? I may not help much, but I don't read a question here.
Chris
SolidWorks 13
ctopher's home
SolidWorks Legion
RE: Flow Simulation
Also, I think you have to have special surfaces defined, at the inlets and outlets, as if they were membranes or something. It's been a while since I actually had SW to screw with, but I remember having problems with that.
Mike Halloran
Pembroke Pines, FL, USA
RE: Flow Simulation
Mike Halloran
