Random Point Selection Issue
I've referenced this forum for quite a while but have never needed to post until now. I have to sets of data points taken from a CMM. When I select all of the data points in one set, it will number them in a difference order each time. I tried keeping the view the same but that did not work. I tried searching in the customer defaults for some point selection method but could not find anything. Any ideas why this might be and what to do to fix it?
Thanks in advance!
-Ben
Data set 1
http://files.engineering.com/getfile.aspx?folder=5...
Data Set 2
http://files.engineering.com/getfile.aspx?folder=f...
