Fastener edge distance in chem mill skins.
My company uses a 2D minimum for fastener-to-edge in their manufacturing acceptance practice. Less than (2D) requires an engineering disposition (the company still operates under type certification). I am questioning if fastener-to-chem mill pockets follow similar requirements, throughout the industry, or is there a specification which outlines best practices.
RE: Fastener edge distance in chem mill skins.
I believe that the edge distance of 2D for fastener position is to do with bolt tear out in the joint and is usually the norm for most bolting applications and the minimum I have seen is 1.5 x bolt dia as an edge distance however this link might help
http://www.pulsaraviation.com/techdata/737%20NDT%2...
for me the edge of a chem-milled pocket isn't an "edge" 'cause the sheet continues beyond the "edge". it is probably good design practice to aim for 2D but i's accept a design that goes under this. i'd accept a rework that went under 1.5D. for me the important point is "does the rivet head sit nicely on the inner face ?", anything less than 1D is probably no good.
btw, composite panels are completely different !
Quando Omni Flunkus Moritati
Same argument for edges to milled skins. If the subject fastener is located on the thin material section of the boundary - provision must be made to ensure the bucked shop head (or collar diameter) does not notch the edge of the material & contribute to a "stress riser". Gap 0.1" from edge of the shop head / collar would be typical. Also note that stress risers can also arise from the edges of bucking bars or Sockets during installation of the subject fastener. Clearance has to be allowed.
If the subject fastener is located thru the thicker section of the boundary - the panel loading has to be known. Should this be a compressive panel (belly skin) then lowering the edge distance is not serious. Should this be a tensile panel (crown skin example)then the DTA / fatigue individuals of your company will most likely want to have a chat with you.
I seen numerous examples where we required blending on the opposite side of the thickness boundary due to lightning strikes & stress+DTA would not allow it due to the potential stress concentrations arising from thinner material overlay (10% thk reduction) on a milled edge. We ended up cutting it out & installing a doubler.
Also .. what is the quality of the milled radius - is it finely machined (or chem etched) .. or is it jagged + situated in a tensile panel + located in the corner + subject fastener installed with 2nd rate workmanship. Can we anticipate an issue here in 20K cyles from now?
I think the first question I would ask is "what is the fastener head style on the flat side of the sheet [opp side from CM-step]: protruding, flush-shear [shallow countersink] or flush-tension [deep countersink]"?
The second question I would ask is "where is the fastener tail relative to the CM-step: adjacent to the CM-step or isolated from the step by another layer?"
The third question I would ask is: can the fastener [rivet, Hi-Lok, bolt, etc, flush or protruding, etc] develop full bearing/shear-out strength if it were installed in the [adjacent] thin section: or does it need the full section depth to develop full bearing/shear-out strength and stability?
Does the assymetry of the step from A to B [relative to a constant thickness across the area] make a significant difference in loading?
Configuration is every thing.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant – "Orion"
