Inventor Loft problem
Hiya -
need urgent help on the attached file.
Basically i need to loft the two halves of the circle & the ellipse, while following the R175 circle as a guide/rail.
really struggling
anybody have an idea??
really struggling
RE: Inventor Loft problem
You do not have an R175 guide rail in the file - only a construction arc.
If you edit Sketch1 and change the R175 to normal linetype rather than construction - it works fine for a Loft Rail.
