(C++) Changing the selection scope to hole assembly in a block styler dialog
I have a block styler dialog with a curve collector block.
There I want to access a curve in another part of the assembly. That works fine if I change the scope manually to 'hole assembly'.
Is there any NXOpen- or C- function to change the scope, or is there any flag I can set in the block styler definition, so the user does not have to do this manually?
