Aviation Obstruction Light
Does anyone know of a maunfacturer that sells a retractable lighting mast that elevates to ~12 feet. I have a client that needs to install an aircraft obstruction warning light that needs to extend an additional 12' from the top platform of a very tall structures about 90 feet in the air. I have a phone call into Cooper Aviation Lighting systems, but was hoping to get other manufacturers that are in this market.
Thanks in advance.
RE: Aviation Obstruction Light
Why does it need to be retractable for re-lamping purposes?
Yes I failed to mention that the retraction feature is for re-lamping. I was given a vendor by a field engineer from Crouse Hinds Aviation lighting division.
I don't know if the platform at this particular location can handle a mast at ~25 feet, but this is exactly the application the structural engineer is looking to implement.
http://www.halibrite.com/pdf_info/Specs/TipdownPol...
