Adding a line normal 2 a surface in a loop
i want to construct lines normal to a face using the centroid as a reference, but, some how one of the two references for addnewlinenormal is not working, it says it requires an object. what am i doing wrong?
For i = 1 To X
Set objsel = CATIA.ActiveDocument.Selection
objsel.Clear
objsel.Search "Type=Topology.Face,all"
X = objsel.Count2
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set Selection = partDocument1.Selection
Set reference1 = Selection.Item(i).Reference
Set spabench = partDocument1.GetWorkbench("SPAWorkbench")
Set mymeas = spabench.GetMeasurable(reference1)
myans = mymeas.Area
data_file.WriteLine ("Cara #" & i)
data_file.WriteLine (myans)
'****************Centroides
Set centroide = spabench.GetMeasurable(reference1)
Dim mycoord(2)
centroide.GetCOG mycoord
xc = mycoord(0)
yc = mycoord(1)
zc = mycoord(2)
'***************Creacion de los puntos de centroides
Dim punto As HybridShapeFactory
Set punto = part1.HybridShapeFactory
Dim coord As HybridShapePointCoord
Set coord = punto.AddNewPointCoord(xc, yc, zc) 'Variables
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1")
hybridBody1.AppendHybridShape coord
Dim reference2 As Reference
Set reference2 = part1.CreateReferenceFromGeometry(coord)
data_file.WriteLine "Coordenadas del centroide"
data_file.WriteLine ("X: " & mycoord(0))
data_file.WriteLine ("Y: " & mycoord(1))
data_file.WriteLine ("Z: " & mycoord(2))
part1.Update
'*************************creacion de la linea normal
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim solid1 As Solid
Set solid1 = shapes1.Item("PartBody")
Dim hybridShapeLineNormal1 As HybridShapeLineNormal
Set hybridShapeLineNormal1 = hybridShapeFactory1.AddNewLineNormal(reference1, reference2, 0#, 20#, False)
hybridBody1.AppendHybridShape hybridShapeLineNormal1
part1.InWorkObject = hybridShapeLineNormal1
part1.Update
thanks in advance
For i = 1 To X
objsel.Clear
X = objsel.Count2
myans = mymeas.Area
Dim mycoord(2)
xc = mycoord(0)
yc = mycoord(1)
zc = mycoord(2)
part1.Update
Dim body1 As Body
Dim solid1 As Solid
part1.Update
thanks in advance
RE: Adding a line normal 2 a surface in a loop
I've done some small corrections to let the macro create the CoG for all faces first.
CODE --> CATScript
Sub CATMain() Set objsel = CATIA.ActiveDocument.Selection objsel.Clear objsel.Search "Type=Topology.Face,all" X = objsel.Count2 For i = 1 To X Set partDocument1 = CATIA.ActiveDocument Set part1 = partDocument1.Part Set Selection = partDocument1.Selection Set reference1 = Selection.Item(i).Reference Set spabench = partDocument1.GetWorkbench("SPAWorkbench") Set mymeas = spabench.GetMeasurable(reference1) myans = mymeas.Area '****************Centroides Set centroide = spabench.GetMeasurable(reference1) ReDim mycoord(2) centroide.GetCOG mycoord xc = mycoord(0) yc = mycoord(1) zc = mycoord(2) '***************Creacion de los puntos de centroides Dim punto As HybridShapeFactory Set punto = part1.HybridShapeFactory Dim coord As HybridShapePointCoord Set coord = punto.AddNewPointCoord(xc, yc, zc) 'Variables Dim hybridBodies1 As HybridBodies Set hybridBodies1 = part1.HybridBodies Dim hybridBody1 As HybridBody Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1") hybridBody1.AppendHybridShape coord Dim reference2 As Reference Set reference2 = part1.CreateReferenceFromGeometry(coord) Next '*************************creacion de la linea normal ''I didn't wrote your code here End SubUp to here the modified macro is working good but after that where is Set reference1 in your macro ?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
objsel.Clear
X = objsel.Count2
Dim varlinea As Integer
varlinea = objsel.Count2
'********************CICLO*************************
'****************Areas
For i = 1 To X
objsel.Clear
Set ref1 = Selection.Item(i).Reference
Set centroide = spabench.GetMeasurable(ref1)
Dim mycoord(2)
xc = mycoord(0)
yc = mycoord(1)
zc = mycoord(2)
Set coord = punto.AddNewPointCoord(xc, yc, zc) 'This is where i create a point on the face centroid
part1.Update
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim body1 As Body
Dim solid1 As Solid
Dim reflinea2 As Reference
Set reflinea2 = part1.CreateReferenceFromObject(coord) 'reference for the point
Dim reflinea1 As Reference
Set reflinea1 = part1.CreateReferenceFromBRepName("RSur:(Face:(Brp:(PartBody;" + CStr(varlinea) + ");None:();Cf11:());WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)", solid1)
'i had to create a reference from the BRepname of the face, it is the only way i found to make it work. using varlinea value to create a reference for every face of the part.
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapePointCoord1 As HybridShapePointCoord
Set hybridShapePointCoord1 = hybridShapes1.Item("Point." & i)
Set hybridShapeLineNormal1 = hybridShapeFactory1.AddNewLineNormal(reflinea1, reflinea2, 0#, 20#, False) '20 mm, it could be anything.
part1.Update
'its only working for .IGS
thanks a lot for your time ferdo, i had to create the line normal inside the cicle.
Fernando
