Macro to load license
I often charge a license in 'shareable products' such as the SPA license.
How do I create a button to activate / deactivate a license?
thanks
RE: Macro to load license
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
Dim settingControllers1 As SettingControllers
Set settingControllers1 = CATIA.SettingControllers
Dim memoryWarningSettingAtt1 As SettingController
Set memoryWarningSettingAtt1 = settingControllers1.Item("CATSysMemoryWarningSettingCtrl")
Dim licenseSettingAtt1 As SettingController
Set licenseSettingAtt1 = settingControllers1.Item("CATSysLicenseSettingCtrl")
  Dim Message, Style, Title, Response, SecString
    Message = ("To get the SPA license click YES, to release it click NO" )
    Style = vbYesNo + vbDefaultButton1    'Define default button
    Title = "Purpose : change status of a specific license "
    Response = MsgBox(Message, Style, Title)
If Response = vbYes Then    ' User chose Yes.
Dim generalSessionSettingAtt1 As SettingController
Dim disconnectionSettingAtt1 As SettingController
''''''''''''''''''YES
licenseSettingAtt1.SetLicense "SPA.prd", "SPA.prd"
Set generalSessionSettingAtt1 = settingControllers1.Item("CATCafGeneralSessionSettingCtrl")
generalSessionSettingAtt1.SaveRepository
Set disconnectionSettingAtt1 = settingControllers1.Item("CATSysDisconnectionSettingCtrl")
disconnectionSettingAtt1.SaveRepository
memoryWarningSettingAtt1.SaveRepository
licenseSettingAtt1.SaveRepository
Else
''''''''''''''''''''''''NO
licenseSettingAtt1.SetLicense "SPA.prd", "NotRequested"
End If
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Do you have to fix the code if the license is on another server? I tried to run this macro at my job and indicated an error on this line:
that license is available (manually).
Hi Ferdo,
do you have some news?
thanks
Biricio,
Any luck on getting this to work?
I have been unsuccessful trying to get the same thing to work for our Sharable Products.
No, unfortunately Ferdo has not responded.
I would like to have a button to activate / deactivate a Sharable Products.
Ferdo where are you? We are waiting you.
CATIA doc referes to CATSysLicenseSettingCtrl for Licensing and CATSysDynLicenseSettingCtrlfor shareable product
I let you pout A and B togeteher
Eric N.
I have tried to put CATSysDynLicenseSettingCtrl instead of CATSysLicenseSettingCtrl...but nothing.
bye
Biricio,
FYI I tried the same, did not work for me.
FERDO, do you have any news?
bye
Hi Ferdo,
we can resume the subject.
Can you do some testing?
I really really need this macro
thanks
Do you require that Catia be open for this change to be made?
Garzar,
I believe that I am looking for the same macro as biricio.
Catia would be open.
Run a macro to select/deselect a sharable license such as step(ST1) or space analysis(SPA).
Rick
We done this a number of ways with Catia closed.
I have had no consistent success in doing this with Catia open.
