Liability aspects for segmenting B16.9 elbows on site
ASME B16.9-2012, paragraph 6.2.4 states:
"Although the elbow intended for field-segmenting must meet the requirements of this Standard, once the field-segmented elbow is cut, it is not a B16.9 product."
Now the question arises, does the manufacturer continue to be liable for the elbow?
My first thought is that the manufacturer is no longer liable for meeting the requirements of ASME B16.9. In extension, this would mean that the manufacturer is still liable for the other standards mentioned on the CMTR, for example ASME SA 234.
What are your thought?
Have you had problems with field-segmentable elbows where the manufacturer had to get involved?
RE: Liability aspects for segmenting B16.9 elbows on site
Nobody has had issues with this?
I've had difficulty getting fitting manufacturers to stand behind demonstrable field defects (a tee with a vug that wouldn't hold light, let alone fluids). Give them an out like you quoted from B16.9 and you should expect to be 100% on your own.
I generally trim pipe instead of trimming fittings. Just a personal choice, either is acceptable. If I have to make something like a 19° change in direction, I'll do it in a hot bend instead of mitering pipe or a fitting that much. That way I have a tangent of straight pipe to weld to.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
