Question about 2 monitors and assembly rebuilding?
Hello everyone,
since 1 week i have 2 monitors on my workstation. I think that this is very convenient. Now on my 1st monitor i awlays have an assembly, and on my second monitor i have some part from this assembly. My question is there a way that every time I make some changes on the part, all the changes appear ditectly in the assembly on the other monitor. Because at the moment I have to save the part, then close the assembly, and then open it again....
Thank you.
Thank you.
RE: Question about 2 monitors and assembly rebuilding?
And I also assume that the parts that you're editing on the one screen, running one session, are components that are used in the Assembly on the other screen running the other session of NX, correct?
OK, once you make a change to a part file and save it, go to the session where the Assembly is loaded and go to...
File -> Close -> Close and Reopen All Modified Parts
...and you will be asked if you really want to close the parts and you say 'Yes' and then ONLY the parts which have been changed AND saved SINCE you first opened the Assembly will be closed and the newly edited versions of these parts will opened and will replace them.
So YES, you do NOT have to unload the entire Assembly and reload it. The workflow described above will ONLY effect the parts which have actually been changed and saved since you opened the Assembly.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
it works, but is it possible when NX reopens only changed parts in the assembly, not to change the view also.Because now it returns the assembly in the viewing angle left during last save and i have to adjust my view angle again to see how these changes affect everything.
1) save the view
or
2) save a bookmark (which essentially saves the view)
after you reopen the modified parts, reorient your view or apply the bookmark. Your view will return to where you had it.
www.nxjournaling.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
