Frequent bursting of rupture disks
In our plant, there is a 1" rupture disk combination with a relief valve, along with a redundant unit, which is procured for gas/vapor service (i.e., fire scenario). At a few times when the rupture disk is switched to the redundant unit, the redundant rupture disk bursts as soon as it’s taken in service. The temperature of process stream remains below the specified burst pressure of the rupture disk.
Is the failure due to incorrect fluid service category or due to a possible water hammer scenario which might create a sudden pressure wave? The change over valves between the in-service and redundant unit operate very quickly. The pipe length between changeover valve and rupture disk is less than 5 feet on one side and less than 3 feet on the other side.
I’d be interested in hearing your thoughts on the potential reasons of the frequent failures. Thanks.
RE: Frequent bursting of rupture disks
In normal operation, the process temperature is way below the burst temperature.
You keep saying burst and process temperature. This might be me but bursting discs work on pressure not temperature. BDs are quite fragile things and don't have a lot of give once the pressure (not temperature) gets close to it's set pressure. Any schock wave is not good for a bursting disc so I think you've answered your own question.
Both of the automated valves at inlet of rupture disks have a common actuator and are connected by a mechanical link. When one valve opens, the other one closes simultaneously. This change over happens quite rapidly when we switch to the redundant unit for maintenance, etc.
The existence of water hammer is just my hunch - I'm not really sure whether a sudden pressure wave does occur in our system at the time of change over.
Hope this would help in better understanding of the system.
~GreenHawk
P.S. I was talking about process temperature being below burst temperature setting as rupture disks' actual burst pressure is a function of the process temperature as well. If the process temperature increases above the specified burst temperature, the rupture disks blows off before reaching the burst pressure setting.
I can understand why you refer to temperature, but unless pressure is ONLY affected by temperature then it's pressure that counts as you could have lower temperature but higher proessure from a pump or other pressure source, not just temperature.
The best solution is always ... get rid of the disk.
Check to see if the disk is actually necessary.
