Do standard keyway width tolerances account for offset error from the center of the shaft?
I have a question about keyway tolerances as specified by ANSI B17.1-1967 (R1998). For a 1/8" square key, for a class 1 fit, the width and height need to be .125 +.000/-.002. The key seat dimensions need to be .125+.002/-.000. That would give you a line fit in the worst case, but this does not account for the symmetry(or offset) of keyway about the shaft center. It states that this could be .010 max. This value is likely for a large diameter shaft, such a high number would not be tolerated on a 1/2" diameter shaft, but lets say that the keyway is offset .002 from the center. In a worst case, you would have .002 interference. What if the key slot of the hub was offset .002 in the opposite direction. In a worst case you would have .004 interference. This would make things difficult to assemble, I would think. Am I reading this correct or am I off base?
-ren
-ren
RE: Do standard keyway width tolerances account for offset error from the center of the shaft?
Mike Halloran
Pembroke Pines, FL, USA
Now, renasis, if there are reference features other than the key and seats, of course then there may be asymmetries, that you typically correct with an 'offset key'. ... or you may wish to insert an intentionaly asymmetry.
An easy to find example is engine timing gears or sprockets; tuners often wish to advance or retard the cam by a fraction of a degree, much less than the tooth pitch. So speed shops stock offset keys, and sprockets with multiple keyseats, each offset by an integral multiple of the angular tooth pitch plus a degree or fraction.
Mike Halloran
