Line Normal to a surface
i need to construct a line normal to a vector, so i can calculate a unitary vector to a certain face.
i am using the command addnewlinenormal but i have to do it for a whole set of faces.
Set objsel = CATIA.ActiveDocument.Selection
objsel.Clear
objsel.Search "Type=Topology.Face,all"
X = objsel.Count2
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set Selection = partDocument1.Selection
Set ref1 = Selection.Item(i).Reference 'First reference
Dim punto As HybridShapeFactory
Set punto = part1.HybridShapeFactory
Dim coord As HybridShapePointCoord
Set coord = punto.AddNewPointCoord(xc, yc, zc)
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1")
hybridBody1.AppendHybridShape coord
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim solid1 As Solid
Set solid1 = shapes1.Item("PartBody")
Dim reference2 As Reference
Set reference2 = coord 'Second reference
Dim hybridShapeLineNormal1 As HybridShapeLineNormal
Set hybridShapeLineNormal1 = hybridShapeFactory1.AddNewLineNormal(ref1, reference2, 0#, 20#, False)
hybridBody1.AppendHybridShape hybridShapeLineNormal1
part1.InWorkObject = hybridShapeLineNormal1
all references should be complete eventhough its not working. THANKS in advance
RE: Line Normal to a surface
by the way, the error that i came up with is '424 Object requiered'
