Effect of Oil on Refrigeration Exchanger
I am designing Refrig Plant for Propane cooling (-50C) using R410a. The compressors are oil injected screw and there is oil recovery, however there is oil carry over into the Heat Exchangers.
Is there any papers/ software available to calculate the performance degredation due to the oil film on Heat Exchanger tubes.
RE: Effect of Oil on Refrigeration Exchanger
