Cutting tool for turning operation
I am working on optimisation of process parameters in maraging steels using taguchi method. In this connection would anyone suggest me suitable cutting tool for turning maraging steel samples. Maraging steel i am using is 18Ni1700. Thanks in advance
RE: Cutting tool for turning operation
Plymouth Tube
- alloy in the solution treated condition (soft) or aged condition (hard)?
- rough or finish turning?
- coolant or dry?
You can find data on feeds, speeds, and insert types by using the following links:http://www.ingersoll-imc.com/en/products/uc/1344_T...
http://www.mitsubishicarbide.com/mmc/en/product/pd...
